· Registered
So I was hoping someone could explain to me what is the deal with these aquamist water injectors? I understand how they work and that they are used to prevent detonation. So I guess what I'm asking is if I were to put a stage 3 tune on my 2003 9-5 aero and also put a aquamist injector would I be able to still used regular octane fuel (US) and get the same performance?
· Registered
Why does everyone think they'll save a meaningful amount of money using regular????? Your car is designed for premium, use it! :evil:
· Registered
If you're installing Aquamist so that you can run lower grade fuel, you're doing it for all the wrong reasons. Based on the lowest cost I just found with a quick web search, you'd have to purchase ~2500 gallons of fuel and drive ~66,000 miles to recoup the cost of the aquamist system (based on a $0.30 difference between 87 & 93). That is NOT taking into account the methanol solution you must purchase to use in the system.
· Registered
Must say that do notice the difference with 97/98 RON in the UK. It is more costly but you get more Power. My Dads A8 also states that you should run it on super!
