HI,
Does any one know where the 12v comes from for the APC solenoid?
On starting the car I am led to believe that there should be an audible click from this solenoid.
I removed it today and checked that it is functioning correctly which it is.I have a good ground,but only seem to get around 8volts and I think it is shorting to earth.If I run a wire from the battery I can get the solenoid to Click.
The boost needle is only going halfway up the yellow and my cruise control is not working is this all linked,As you can tell I am no expert just keen to get boost:)
Cheers
If the APC solenoid were not working, your problem would be too much boost, not too little.
Cruise control limits boost, but only if it's working.
I see,I have found a bad earth to the solenoid.I get a click from the solenoid when there is power now,but I still only get boost half way up the yellow and everynow and then the solenoid will click for a few seconds then stop;oops: .
I printed off some stuff from 900aero.com last night,I will have a read at lunch time for some clues
