OK so here is my what i think to be an issue, im hoping it will lead me to my under powerd problem. I did the apc pull the line off the top port and plug the vac line deal, but if i go and hook up a vacuum cap to the APC top's port it will only boost base boost and once i remove it it goes up to 1 bar, is that supposed to happen or if there something else going on?? any help is great
you are saying that you are plugging this line? if that is the case this will cause the actuator to hang open as the pressure will have no where to bleed off when the actuator returns to its original position
APC module cleaning.
Could this help ? I believe there was a post some months ago to remove this unit, clean with WD 40 and replace. Perhaps someone still remembers this thread ? ?
