1 - 2 of 2 Posts
Hullo there, just bought a 16v non-turbo 1989 900/US version. To my surprise APC box is there. Thought it comes only with FPT turbos. tacho without boost indicator and no air cooler, so engine swap (fpt to n/a) rather excluded.
Is then turbo instalation possible/easier with APC already there?
Moderator
Are you sure that's an APC box? It's more likely the EZK ignition contorller. If your distributor has no vacuum capsule and no electrical connection {apart from the HT leads} and if there's a knock sensor on the block {look between pipes 2 and 3 of the inlet manifold then you have EZK ignition. http://www.saabcentral.com/forums/search.php?searchid=164655
And no, N/A to turbo conversion is generally considered to be too much work to be worthwhile, even for geeks like us...
1 - 2 of 2 Posts
