help i have bought 3 gauges for my aero the water one i have just used the sender unit i got with it and screwed it into head whet temp sender was and this has made wy cooling fan work when engine runs and stops 5 mins after engin turned of.... runs engine cooler and i think this will be fine any ideas???
next is tricky one oil temp sender needs to be in oil, so sump is best i think need to drill hole in sump and fit there, trouble is has anyone done this and would i need to weld a nut on to the sump to screw sender into or justtap sump...
though dont think this would be strong enough without nut welded to it or is there a better place to put it
any help would be great
Oil sender needs to be the correct one for your gauge, and it replaces the sump plug, it just screws in and you run a single wire back to the dash.
Do a search, lots on this topic.
Good luck!
tried a search yesterday but turned up nothing, will have a go again mate,
the sender unit supplied with the gauge is too fine a thread for the sump plug have a spare sump plug and its not the same, any other ideas
what do you think of the water temp gauge in respect of the sender unit thats with the car, i think it now runs cooler than before always thought the saab ran too hot anyway, since i have fitted the new sender and took the saab one away its seems fine and only runs on about five mins after engine turned off.
cheers kev;) ;)
