1 - 7 of 7 Posts
· Registered
title says it all. i can buy a set of aero injectors for my linear for about 20 dollars for all 4 :cheesy: . should i get them? and if do is it easy to do?
· Registered
yea i would go for a custom tune this summer
· Registered
not sure yet. i will probably go to MP performance in canada as my family vacations there in the summer so its real close
· Registered
That's short money, but don't install them. This is a pointless change unless you're producing the airflow to match the fuel. If you just swap out injectors, you'll just be wasting fuel and running unnecessarily rich.
You won't need injectors until you increase the airflow substantially, which usually means a larger turbo. If you're planning to do that, you'll need more plumbing to support that mod, so the injectors will only be part of a longer list....and the Aero injectors won't be on them.
And I'd check whether MP Performance actually does "custom" tunes...
GOod luck!
· Registered
yea, I wouldnt bother; The stock injectors have enough flow to cover the airflow your turbo's capable of producing; by the time you're outflowing them you'll want to upgrade to significantly bigger injectors anyway (if the aero injectors are actually any different than yours)
1 - 7 of 7 Posts
