I've got mine on the way as we speak and I want to replace those exhaust tips for something that will fit the maptun diffuser.
I don't know crap about exhaust tips so what size will I need to replace those giant exhaust tips?
What is the BSR exhaust tip's length at the widest point? 2x85/150 makes me think its 150mm WIDE. Please tell me I'm wrong.. :(
http://www.jegs.com/i/Magnaflow/642/35136/10002/-1?parentProductId=
Would these tips be compatible?
The BSR tips are 4 inches in diameter I believe. Same as maptuns exhaust tips. 4 inches seems to be the norm for aftermarket exhausts on the 9-3. My ferrita system has 4 inch tips. Your biggest concern will be how far they stick out past the diffuser. I had to cut the stalks to the muffler nearly 2 inches, and the pipes on the tips another inch to get them to factory position. They stick out really far if you do nothing about them
The tips should be 100mm wide, BSR's page says they are 100mm tips which is 4 inchs diameter. The tips themselves on the BSR I believe are welded straight onto the mufflers. Maptun tips are also 4 inches so they will fit under their diffuser as intended. I wouldnt spend the money on new tips since the ones you posted will be just about the exact same as what is already comes
