1 - 2 of 2 Posts
I was changing a vacuum line the other day and noticed this was broken. Right now it is held together with some tape and a zip tie, but i would like to find a new one. Not sure what to really search for i know it is a check valve but not sure where to start. http://www.saabcentral.com/forums/attachment.php?attachmentid=30214&d=1340851356
If the check valve is ok you can simply buy vacuum line (i'd suggest fuel line of the same dimension as it's better with oil vapor then regular vacuum line which could seep eventually). If the valve is broken...
http://eeuroparts.com/Parts/PartDetail.php?partCode=9399973A&diagramId=1149&diagramNumber=7
1 - 2 of 2 Posts
