1 - 8 of 8 Posts
I've flipped through quite a few of the available write-ups for other members 19T (JZW Stage 5+) install, however I'm not seeing any clear instructions on how to swap out the injectors? Anybody know of any DIYs out there? Thanks!
Sub'ed...wouldn't mind getting answer on this too. I'm going to be purchasing the injectors from a tuner soon and had assumed tuner would provide the instructions?
Thoughts on removing intake manifold gasket and whether it needs to be replaced with a new one after reassembly?
The intake manifold gasket is a composite metal gasket, and although WIS says replace after removal, it holds up really well and should not need to be replaced.
anyone know where i can get link to an online manual? replacing the turbo on my 2000 9-3 b205l
Go here. Sign up on his mailing list. He will email you the link to download WIS & EPC versions that he has created to work on 64 bit OS. Then, go to this thread and read the whole thing to find out how folks downloaded it successfully and changed the language to English.
Discussion Starter #8
Thanks guys for all the responses! Job wasn't too bad, and the wis documents explained perfectly. Only snags were a banjo bolt from the turbo falling into the gap next to one of the exhaust heat shields and the battery mysteriously dying as I reflashed the stage 5 tune ( thought I'd totally bricked the ecu)
Sent from my iPhone using Tapatalk
1 - 8 of 8 Posts
