1 - 12 of 12 Posts
I went to install my 3" DP and subframe brace on the lift the other day and my mechanic noticed a pretty good sized hole near the back of my exhaust! Looks like the muffler was rubbing against the parking brake cable causing the hole! Im assuming it was from lowering the car!
hmmm, you didn't hear any differeance?
I'll go check mine to see if there are any signs of this. What springs do you have?
My Saab is not lowered but when i went to replace the stock exhaust with the Saab sport exhaust i realized the stock had a big dent right where your hole is.
its gotta be. Mine that is lowered by 1.2" is fine, no problems at all!
Discussion Starter #9
i got the vogtland springs that lower 35mm which is equal 1.378"
maybe this explains why sometimes my parking brake doesnt grab? i have to lift it like 3 or 4 times sometimes!
I would think this could definatly be connected to your parking brake. It may be getting hung up on the exhaust. Next time you have a problem, see how the real wheels are fitting in the wheelwell. If you're parked in such a way that they are up farther, this might make it harder to use the park brake.
It is odd that the extra .18" would even make a difference. Just for referance, is this the stock Saab exhaust or what?
So i crawled under my Saab this weekend to put on the new sway bar and the exhuast has definately started to melt by brake cable a little too, and my Saab isnt lowered.
Discussion Starter #12
Interesting.......
Do you think this hole could be the cause of my hesitation/power loss issue im having? Backpressure related!
At WOT i can hear the exhaust leaking out of the hole.
Nonetheless I guess that just means new exhaust from dp to muffler :cheesy:
Should i do 2.5" or 3" from dp to muffler??
1 - 12 of 12 Posts
