Hi again,
Has anyone got a how to guide for replacing front anti roll bar bush on an aero.
May be called sway bar bush on your side of the pond.
Cheers David
The bushings aren't that hard to replace. If your new bushings have a slot, you can undo the the bolts, pull/cut the old bushings out and slide the new ones in. If they aren't cut, you will have to undo the end links and slid them in through that way.
