1 - 2 of 2 Posts
Hi All,
Repeated P0768 codes been thrown by my 2004 Aero. The unusual thing is it seems to be occurring when I drive over a particularly bad bump in the road. Twice at the same place. Once I clear the code the car drives without issue. Would it be possible that what ever angle the car is tilted to, the shift solenoid gets knocked or lose or affected?
Thanks in advance,
Mike
Test procedure in the WIS is to check the wiring first and if that all checks out OK then change Solenoid S5.
You may be lucky and the fault will go away without doing anything but usually it will gradually get worse with the transmission going into limp mode after a few driving cycles.
1 - 2 of 2 Posts
