I'm gonna try and explain this with the least amount of words i can but it probly will get a little wordy so sorry up front.
First - 1990 Turbo vert 5 speed, 277k miles on the clock and could be more since when i got her, the speedo was not working (it is now).
She's been my DD for nearly a year now. Back around last sept she started having this intermittent miss. Out of the blue she would just start chugging. No power although i could actually keep driving after few minutes it would go back to normal. This would happen every few days or so but when it wasn't missing, ran fine.
At that time, i decided to take the cap and rotor off, clean it up, put it back, also pulled all the plugs. they all pretty much looked normal. After i got her back together the miss never came back until this past week. I did the same thing this time(pulled the cap/rotor and all the plugs. Cleaned up where necessary but no luck this time). Btw, the cap/rotor, all plugs and plug wires replaced last spring. Now, she seem to be having this issue about 50% of the time.
I was thinking that maybe I had an injector going bad but not sure if they are prone to be intermittent bad/good. I have a set of injectors from an '87 that i cleaned up and swapped out but she would barely run with those in. I guess they are not interchangeable with the earlier injectors.
Oh, also, i just did a compression test - 1,3,4 cylinders are @123 and #2 is @110).
So i found something interesting, when she's running bad and missing, if i pull the plug on # 4 injector i dont hear much of a change. But if i pull any of the others she will choke and die.
So, i ordered a set of refurbs off ebay and will swap them out next week. But do you think an injector could act like this?
Thanks for any insight
