Slight emergency regarding my timeframe here, have done some searching but thought I would toss out the specific symptoms and see if anyone is familiar with them. Car is a 2000 9-3 5-spd base model.
Yesterday, responded POV to a fire department call and left my engine running with red lights on to block traffic. Noticed over a few days prior the temp gauge would dip while driving.
At the scene, I turned it off after about 20 mins. When I got back in about 30 mins. later, car wouldn't start. After I let it cool about 45 mins with the hood up, car started again. I added coolant since the reservoir tank was empty, which certainly caught my eye.
No smoke on startup except for a puff a week ago, figured it was due to the seafoam I had put in the fuel. New radiator and coolant in September after old one developed severe leak at ~140k.
Bought a thermostat on the way home today due to prior reading. Tonight I got home and saw coolant was a little bit low again. I am barely even an amateur at mechanic stuff, so I decided to see if I could burp the system before doing anything more complex.
Coolant (Dex-Cool orange) overflowed with the cap off. I replaced the cap and turned off the car, waited until coolant retreated from reservoir, and added a bit more to replace what was lost (maybe half inch below KALT mark).
I waited a bit and started it again, to see if it would have the same problem as at the fire call. Started right up, ran with the hood open a few minutes, temp gauge right in the middle.
Closed the hood, watched the temp gauge another three or four minutes, still sat in the middle. [EDIT: Fan came on and went off when I switched on A/C, but not otherwise.] Then suddenly the driver's side upper radiator hose to the motor blew violently, ripped clean in two.
No milky oil on the dipstick. I plan on installing the new t-stat and replacing the hose this weekend.
Any help or direction to an applicable thread would be much appreciated.
Thanks in advance!
Thanks in advance!
