2006 Saab 9-3T
Just had My amp 1 changed out after having no radio or blinker click. Now all it does is just flicker on and off. My mechanic spent 2 hours on it with tech 2 and couldn't figure it out. Pulled the radio and rechecked both amps and fuses. Please help. I used saabradio for a new rebuild
2006 Saab 9-3T
Can the REC cause any problems with this. I saw it somewhere I think that it has a computer? The amp 1 I has put had a brand new circuit board and all. When it first happend I pulled fuses and it worked. Just now remembering that the right rear speaker started popping right after the rear of the car got hit with water from a carwash. Didn't find anything wet after. But just noticed my rear deck is a little damp and that my rear window is missing some of the seal. After shutting the car off after the popping speaker it stopped completely. I have the 13 speaker. Amp 2 was swapped out to try a different one when my mechanic went over it. But still nothing.
2006 Saab 9-3T
My mechanic Just tried amp 1 bypass and nothing changed. Still not working.
Bypass whole O-bus and report back.
