Hi,
I pulled an AMM from a N/A 16v car (1989 YM). Is this part usable on other models or only on N/A cars?
Thanks, Seb
Yes it's a Bosch EFI. So turbo models use a different AMM?? What was the 89 change? Lucas EFI? I'm not familiar with later 900's...
Thantks for your answer, Seb
grif900 said:
If the car has bosch injection, then it will work on a N/A car from 1986 to 1989.
For Bosch (I don't know anything about Lucas), air mass meters are matched to whatever version of Jetronic they use. For NA cars: 86-87 used LH2.2; 88-90 used LH2.4; and 91+ used LH2.4.2.
It does not matter if the car is turbocharged or not; what matters is the Jetronic version. Therefore, the '89 NA meter he pulled (Bosch -013) will fit 88-90 NA 900s, 89-93 900Ts, and 89-90 9000Ts because they all have LH2.4.
http://genuinesaab.com/psi/files/exchangeparts.htm
