Alternator not showing battery light
123 1
Hi, I am using hiluxy with 2y engine. I am having a challenge with alternator it doesn't turn on the battery light before starting. I use lucas alternator so after l start l short circuit the connection on the alternator and then get charging. Will this allow me to drive long distance? And what can be the problem?
Thankyou
1 - 2 of 2 Posts
Hi and welcome.
Have you double checked that you have correct battery light in dash and wire is intact between battery light and alternator?
If yes, you have bad alternator.
1 - 2 of 2 Posts
