I have searched extensively & all the info has been great, but I'm still confused.
I have an alpine 9885 with ipod connector and steering wheel controls. I have also purchased the mounting kit for the 9-5.The mounting kit comes with two harnesses, but neither fit the rear connection of the alpine.
1) So, do I have to use the harness that comes from the back of the alpine and clip the connector off of the harness that came with the kit, then wire them together?
2) Will I need to splice both harnesses supplied with the kit to the alpine wire harness to get it to work?
3) ThenI should be able to just use the RCA trick to connect it to the amp in the car?
4) Are there any electrical connectors that I can use to fit into Saab wiring harness. This would prevent me having to cut the connector off and would make things look nicer?
