I recently purchased new 17inch rims along with low profile tires. After these rims and tires were installed the car was pulling to the left extremly bad and would wobble around 50-60mph. I have taken the car back to get spacers and a realignment which took away most of the pull and all of the wobble. However the specs from the alignment diagnostic showed a negative camber of 8% which is the reason for the pull. The mechanic said he would try a new tire to see if that would fix the problem, but i am a little skeptical. Unfortunately there are now camber plates so i was wondering if there was some advice, other than give up my new rims!!!! Thanks
