Please don't "shout" Jaluu, i hear ya loud 'n' clear...
Right, instructions for airbox removal as follows..
1. remove front grill
2.remove right headlight and indicator unit
3.slacken the retaining clips, and disconnect the intake pipe from the top of the air cleaner housing
4.apply hand/emergency brake, then jack up the front and support on axle stands
5.remove r/h front wheel, undo retaining screws and remove wheel arch liner
6.from underneath, slacken the retaining clip, and disconnect the intake pipe from the bottom of the air cleaner housing
7.unscrew the lower mounting nuts, and lower the air cleaner housing from under the inner wing (you may need to remove a couple of bumper retaining screws from the right hand side to allow removal of the housing)
