06 9-5. Replaced my clockspring with a supposedly good one from E-Bay and still get the airbag light and beeps whenever the steering wheel is turned. Does anyone know if I need to re-set anything with a Tech II? Don't really want to do another clockspring at this point if there's something I've missed. There's been some mention of checking bad connections in the steering column but any other advice would be appreciated. Thanks.
I had same issue which occurs especially when outside temp is around 0 to 5 C. I changed new clockspring, no help.
I changed connector in dash, no help.
I changed (used) steering wheel wiring loom, no help. At this time Saab did not have new steering wheel wiring loom in stock.
Finally I changed new steering wheel wiring loom and it helped. Saab have now few new wiring looms in stock.
I highly suggest that you read DTCs with TECH2 first.
