1 - 8 of 8 Posts
Every time I go to read DTC’s the Tech2 says the ACM was added, and when I clear DTC’s the Airbag malfunction message pops up on the SID. There are never any codes for airbags, nor does the message ever pop up in regular operation. What gives? Should I care?
did all that happened out of the blue ? Nobody did play with the tech2 or any service was performed on the car recently ?
Also, can u provide a screen shot of the fault stored ?
It’s happened since I bought the car in August. The code I’m usually clearing is the P0089 Fuel pressure regulator, which the car throws every so often. There are no codes related specifically to the ACM. This time, however I got the CIM error, but it’s the first time I’ve gotten this error since I cleared everything in the car shortly after buying it.
How about u perform add ACM .. and report back what is the result of the add is it success or failed, and if the condition persist after adding it
I think I tried that already but I’ve forgotten for sure so I’ll do it again.
Discussion Starter #6
That did it. (And I thought I’d done it, but I guess I just thought of doing it.). Thanks
  • Like
Reactions: Hus_sho
1 - 8 of 8 Posts
