Hi all,
I have a 2000 9-3 Aero. Under normal conditions my air-con works well, however recently during extreme heat it dies after about 45 mins and only leaves me with a fan. This occurs after the first 'start up for the day'. The cabin sensor was screaming - so I did remove and clean it / vacuum dust etc - and I reset the ACC. No bars appeared during the reset - only 0.
When I say extreme - it was approx 45 degrees C (113 F) the other day.
The cabin sensor is still screaming - but only just a little. The cigarette lighter was in place - but not used during that period.
Is this just a case of refrigerant re-gas needed - or should I get a new cabin sensor - or both?
Engine Wise - the car was fine, and I had no over-heating.
Is there anything else I should check?
