Hi All,
I have a high idle problem. Once I drive the car a little ways, the idle eventually creeps up to 1400 RPM. If I turn the ignition off and restart, it will return to a normal idle-speed, even if I rev it, but once I drive it, the idle creeps up again. When it is cold, it seems to start normally with the initial startup idle-flare that settles back down to normal idle-speed. Once it gets warm, the idle gets too high. Once, it restarted with a high varying idle, but only once so far.
I saw an old thread from Peva and that lead me to test the coolant NTC sensor, the TPS, and I also cleaned out the AIC valve with WD-40. The NTC resistance, cold and hot was fine, the TPS had about 13 ohms with the throttle closed and had no continuity with full throttle, the AIC valve had about 10.2 ohms across the terminals.
After I sprayed the AIC valve out with WD-40, I tried to move the little barrel, but could not. Also, the plastic part that fits into the aluminum housing is a little loose.
But if the valve is bad, why is the cold start normal with the programed idle-flare then settling into a normal idle? Wouldn't that require the AIC to be working?
Any clarifications on how this system works and anything else I can do or test is appreciated.
