2004 Saab 9-3 1.9 tid 16v 150bhp
Hello, me again.
2 questions :)
1) is there a way to check oil level without tech 2? I don't think I have a dipstick, and I have read there is a tube attached to the drain plug. Is it a case of taking out the little bolt in the middle and topping up till it starts dripping? Read something about topping up till it drips, refit bolt then add further 0.5 litres but might be wrong.
2) may be gearbox related. I have a basic code reader and car threw a p1902 code a few days ago, hasn't come back since I deleted it. Google is a bit here and there so I'm assuming it's either a valve in the gearbox, or, the exhaust temp sensor?
Thank you :s
1: No
2: Not valid DTC.
If you need help, do not make me guess your car.
Thank you :) will try and look at the connections on the post dpf sensor before replacing, thanks again!
