When I put my shifter cable back in the bracket after replacing the bushing I think I messed up my adjustment because I removed the Cable Adjustment Clip and replaced it.
Any suggestions on correcting this?
Pull out the cable adjustment lock clip (inset pictured) and rotate clockwise to shorten; counter-clockwise to lengthen - as required.
Hi i ve managed to pull the ajsutment clip as you shown on the diagam- do you need to rotate the whole plastic part or there is a moving part around the clip only ? -
I ve messed around and 4 anti clokcwise turn did not elongate my cable...
I know it s been 4 years help would be apreciated
