Grab your trusty digital multimeter and check the voltage to one of the injectors with power on and the said injector not connected to the, well, connector. One of the pins should be 12v and the other 0. If you are getting 12V, then measure the continuity between the 0V pin and ground. It should be open. When you crank the engine it should pulse, as if it is trying to ground. If that is not happening, check pin 1 on the ECU. When the engine crank it should pulse (like 0 to 5V or something). That is the tach signal to the ECU.
