I have some heat issues with my wife's 2000 9-3 (150k, 5-speed) with ACC- it has no heat. I replaced the cabin fan sensor but that didn't do anything (it's time had come). I did the ACC AUTO+OFF self check a few times and within 5 to 10 seconds, the only code that comes up is 06. I can only track down a few codes from the 9-5's, but I did not find any results for code 06.
Can anyone provide any insight or a clue where to go next? I plan to poke around the dash but I need some direction. Great board by the way, it has come in handy several times before for little issues. Thanks everyone!
According to my info code 06 is the "air-mix damper motor". If you go to auto zone and have them hook the scanner up you should have a Non-CEL generating code in memory that is B2492. that would verify. The little motor is located on the passenger side under the dash attached to the airbox.
