Anyone ever had the following fault code and managed to sort it.
B2405
Air Distribution Motor. Flap Loose. Note: May set if not calibrated.
Fault symptoms
Perceived temperature in cabin too high or too low compared to the set temperature.
The air distribution does not correspond with the illuminated symbol in the ACC window.
Conditions
The following conditions apply:
• When the control module runs the stepping motor towards an end position and the stepping motor continues more than 20% past the expected end position, the diagnostic trouble code for loose flap is set.
• The diagnostic trouble code can be set if the control module has not been calibrated.
• Continuous monitoring and when calibrating
