I cleared the dreaded 08 Blend Door code by replacing the broken plastic piece with a metal one.
Still have:
13 - Stepping Motor, Air Distribution Flap
19 - Circulation Pump. Open or Short
Never had the right side of underdash apart - what should I expect? I presume this is the time to replace the cabin air filter?
Is the circulation pump on the engine side of firewall or under dash somewhere? (I presume this is not really needed, that it only helps provide heat when the engine is not running or idling?) Didn't know an '01 linear wagon had a circulation pump... ;-)
circulation pump is easy.
Do you know why you can't find it? Well, The Saab 4 does not have one! Only the V6, so don't worry about a pump you don't have in your car.
for 13 look at blend door on passenger side. Lots easier to get to than the driver side. make sure the rods are all moving properly.
I had the gears inside my passenger side servo motor stripped. and managed to get new ones.
