Hi there, gone through the motions and got the ACC to diagnose and it came up with 2 error codes:
11 and 14, 14 I think is the reason why I cant direct airflow at anything but the windscreen.
I am looking for some one who has done/fixed this before to direct me on how to best do it, from the clicking I have a pretty bad feeling its going to be a motor and right up against the bulk head so any help on how to go about working on it is welcome.
These are the list of codes; sounds like you have a broken blend arm and possibly a bad stepping or fan motor. You have two on the passenger side and one on the drivers side and the fan motor is under the hood under the air inlet screen. Can you hear the fan motor when the ACC is on?
CODE
ITEM
01
ACC internal fault
02
cabin temp sensor
03
solar sensor
04
left mixed air temp sensor
05
right mixed air temp sensor
06
left blend door
07
left blend door
08
left blend door
09
right blend door
10
right blend door
11
right blend door
12
air distribution motor
13
14
15
16
17
18
heater valve solenoid
19
heater circulation pump
20
control circuit blower
21
Recirculate motor
22
Reflash per SB 271-2206
23
control module sensor ground
You should hear the fan motor from inside the car; just put the AC fan on high if it's blowing air rule that out. If it needs to be replaced you will do that from outside.
Well, when the ACC does the diagnostic I can hear a clicking passenger side with my head under the glove box, never thought to stand outside so will go and test that out if I should be hearing a clicking there too ;ol;
