Hi,
The AC on the left drivers side is about 60 degrees F, and gets warmer as you go to drivers side right and pass side left and right. I checked with gauges (I am beginner), but the pressures look pretty solid. Any suggestions? It looks like high pressure builds and low pressure builds kind of at same time and drops at same time? And the compressor cycles on and off every 10 seconds or so? Is this normal? I purchase a new compressor, expansion valve, and condenser, but not sure if I should return it.
Any advice is appreciated! Thanks!
