Hello Everyone,
My schrader valve (low side) is leaking. I am going to get the following tool to replace valve core without discharging the system.
Amazon.com: Mastercool 91490 Standard Valve Core Remover / Installer: Automotive
I also need to get new valve core. The original valve core from eeuroparts.com is $10 plus $15 shipping. I wonder if I can get generic valve from amazon.com.
What kind of generic valve core should I be looking for?
Regards,
Alex
Alex:
You can remove the valve with a tool you can pick up at the local auto parts store for less than $10. Likewise the valve can be had for about $5 locally. These aren't Saab specific parts, they are standard A/C bits.
EDIT: Just re-read your post - If you are trying to avoid a vac and recharge, a tool like this may be worthwhile.
I don't think that tool is going to do the job, from the picture, it's for old school R12 automotive systems, residential, commercial or industrial refrigeration, not modern R134a auto a/c systems.
That screw on tip looks suspiciously like a standard 1/4" flare connector, not the snap on automotive style valves.
I think Amazon.com: Interdynamics VCR-1L Air Conditioning Valve Core Remover and Installer for Schrader Low Side - Pack of 1: Automotive is more what you're looking for.
Nearly any auto parts house should have replacement valves. Looking at my 01, the valve might well be a standard a/c schrader valve, not one one of the larger auto styles and be even easier to find.
This the one?
For some reason your link broke.
Thank you, guys for the replies!
For some reason link keeps breaking, but I order the one you suggested. Indeed my link has R-12 mentioned in reviews, I should have read it more carefully.
Thanks again!
