HI, lately my ABS light and that dreaded triangle has been coming on at the odd time while driving. I checked and cleaned all the sensors and still have the same problem
I'm now looking at the abs module as the problem.
Exactly where is it? There is a wrecker close by with a few saabs the same year as mine. Is it an easy switch?
thanks
Its a real easy switch. Two connectors - one top, one bottom. Its mounted to the end of the ABS pump (that thing under the hood with all the brake lines going to it). You can have yours repaired for under $50 inc. shipping. You can also drive the car without the module installed. Same two lights on the dash and your speedometer won't work.
also.... the odometer doesn't record mileage....
