so I've got the dreaded wonky abs module issues popping up now. Its intermittent and a bit unpredictable. I'll start the car with about a 50% chance i get a warning. sometimes it will go away while I'm driving and my speedo will kick back on, sometimes not.
Before I go about sending it off for repair, are there any connections I should check for corrosion/poor contact that could be causing this? (It seems odd that it will cut in and out while I am driving)
Also wheel speed sensor? what are the chances this is the issue? I've seen it mentioned on a few threads.
only code is code P1625
