1 - 7 of 7 Posts
Pulled right front hub. After putting back together am getting ABS and TCS warnings. ALSO LOST COMPUTER OUTPUT FOR DTE, FUEL MILEAGE, etc.
Question is: Is fault stored in memory even if problem eliminated? Are there any particular fuses to check? If problem is fixed, any way to clear the message?
Thanks
Discussion Starter #2
Also no steering lock
Also tried wedge between module and tower. I think it is sensor at hub I messed with.
Any thoughts?
Eyem not two brite
2007 2.0 T
I think I bunged up the sensor pulling the hub. Got new hub, will report back.
New Hub / Sensor
Same problem: ABS, TCS Stability, no steering lock, gas mileage, speed average, etc.
Link to hub you bought.
Success
After much search, disconnected newish battery, pumped brake pedal 20 times, spooged car side of wheel sensor connection with electrical contact cleaner, drove a few miles and it cleared.
I'm doing tranny fluid now - makes me think the car was designed by morons to be owned by masochists.
1 - 7 of 7 Posts
