???You need an ABS with TCS from a 2000 - 2002 or 2003 vert OG 9-3 with traction control. They all cross over to the same number now so theoretically any should work. That's all that matters.
If you post your symptoms, we might be able to help diagnose if you need the module. Also, adding your location & vehicle info to your profile helps us help you.
TCS is traction control system, its present on all 2001 and later models (at least in the US) regardless of transmission. The ABS control module for TCS equipped cars have an extra row of valves/solenoids (4x3 vs. 4x2).???
I thought TCS was an automatic transmission thing...? The OP has a manual.
My understanding is that any NG900/OG9-3 manual transmission ABS unit will work...that's what I looked for when I needed one (I can't remember what specific car I ended up getting one from). The autobox version was obviously different, IIRC. I still have my old one if a picture would help.
Now that I have access to a garage, I feel Obligated to try the clutch myself. And later other items on the list. I know it involves dropping sub-frame & transmission. I'd love to find a step by step for this intimidating process. I've not found any YouTube help.
Any ideas?
