my abs light came on the other day when i was driving. i shut the car off and it stayed off, i drove it some more and it came back on. the kigfht has not been back on in like 1 or 2 days now y would it have came on in the first place?
the car is a 97 saab 900s 5speed
can any one help? plez n thaks alot chuck
most probable cause is a bad ABS wheel speed sensor, but to be sure you'd have to get the dealer or someone with a GM TechII that can scan Saab systems to retrieve the ABS codes.
my abs light only comes on when i do a quick burnout before a race...but that is only bc the abs sensor sees that one wheel is spinning faster then the other and its disengaging the abs...but if i turn the car off its stays off...or if i just drive a min...the abs will turn back one and the light will turn off then too...hope that helps u lil
drew
Like Diosnoche said get the code read, then you'll know what's wrong. No use trying to guess when the car will tell you...or at least get you in the right direction.
