OKay,
I made the paperclip jumper to bridge across the ABS diasnostic plug that's located in the area between the coolant reservoir and the ABS accumulator tank on my 1990 SPG. I got all 3 wheel sensor missing codes and the 1114 RF inlet valve code. I removed and cleaned all the sensors, blew out the holes with compressed air while spinning the rotor, and cleaned all the connectors to the wheel sensors and the main connector on the ABS distribution block. I cleared all the codes and test drove the car. Everything worked great and the anti-lock light only illuminated normally during initialization and went out as it should.
However, if I drive the car long enough to get it hot, shut it off, and then restart the 1241 error code returns (signal from RF wheel sensor is missing). I've checked and rechecked the wires and electrial connections to the RF sensor, with no visible problems in any of those components.
I've been messng with this problem for over a week and there's a definite pattern / predictablility to it. The error code never appears when the car is cold. It never appears while driving. It only appears on subsequent restarts after the car has been driven long enough to warm it up, shut off, and restart again. Occasionally I'll restart 3-4 times without a problem, but just when I think I have it fixed it throws the 1241 code again.
My inclination is to visit the 91 900 I know at the local Pick 'N Pull and get the RF sensor off of it. Unless someone on this forum can point me another direction.
Steve
Steve
