1 - 17 of 17 Posts
I got the Xmas Tree lights a couple times when driving. I'm guessing that my used replacement controller is starting to go. Might as well have my defunct one repaired to get ready for replacement :)
Who have you used recently that you like?
The last time I was at BBa reman the tech had told me it was a simple solder flow, so similar to the orange relay. He said it would be obvious on the board where the crack would be. Your up for a challenge, tear it appart.
Yeah, it's awful. Well, it probably wouldn't be that bad if you weren't being anal... I was using a utility knife to make the slightest cut possible. I bet BBA or MM etc just uses a Dremel or something. It's gonna get resealed etc. with silicone etc... Nobody is gonna see how surgical you were (or weren't).
Discussion Starter · #15 ·
I've never studied it. Is it sealed as in "plastic melted to plastic" ?
1 - 17 of 17 Posts
