I've been driving my '92 S around for a while with my ABS light on- I pulled the code a while ago and I don't remember exactly what it was but I basically needed to replace the valve block in the engine bay... one of the valves was broken and I couldn't fix it. I found one on ebay but it came out of a '91 SPG- will this work with the ABS computer from the 92? It looks like all the connections are the same so I'm hoping it will just bolt right in.
Most likely it won't be a problem. But maybe you know a friendly SAAB garage/specialist/dealer than you can check the partnumbers for the '91 and the '92 valve block. If the number are the same, you're sure.
Blacky
Hi there,
Did you try to dismantle the valve block assy?
If so, can you post back with details of the how far you proceeded and what you discovered?
Cheers
900i '93
