So, I had the abs module go out with all the symptoms; dash lit up, no speedo, cel, etc. It's an 04 with a 701 module. Found an 04 at a pick n pull and pulled its module which, as hoped is a 701. Installed it and speedo came back and cel went off. However, all the other warning lights are still on; tcs, abs, parking brake, ! triangle.
It was my understanding that this was not a tech II item and that as long as the part # matched(701), it was plug and play.
Wheel sensors and connections all seem to check out.
Open to just about any suggestions at this point.
