21 - 33 of 33 Posts
Make sure that the eBay kit is for your model. I've gone through this with my 9-5. An eBay part listed for the right year but for a 9-3.
Which one is it though? I saw a "kit" on ebay for turbo oil and water lines for like 120ish, I wouldn't mind getting the whole kit and doing them all. But I don't know what that kit includes (nothing in the pics looked remotely close to what I have)
I think the pipe is the oil feed pipe to the turbo.. Can anyone clarify?
Have you checked the exploded parts diagram on eSAABparts.com?
Discussion Starter #23
Yes I have. I also have the EPC. It does appear to be the oil delivery line, I also am afraid of replacing it cause WIS says I have to take off my cat..... I am so afraid of bolts breaking/sensors breaking...
However, I do have an exhaust leak up there somewhere so I kind of want to take it apart.
Yeah, I am concerned about that.
It's a huge pain, not gonna lie. But you'll feel great after you get it done. If you have to take off the cat/downpipe, be prepared to have to drill out exhaust studs. Maybe you'll get lucky with penetrating oil and a torch though. Order new studs and nuts ahead of time.
Discussion Starter #25
Ha well 2 out of 3 cat-to-exhaust elbow are already drilled out and replaced. It is the cat to turbo I am most afraid of. I highly doubt I will get away with penetrating oil and a torch. Also, I have been replacing with just regular bolts and a nut, are studs better or just easier to get together?
Second, anyone know the length of the turbo to cat bolt length? I wouldn't mind getting 3 of those with matching nuts before doing it, but never saw em in person to know what length to get. I also think that is where my exhaust leak is.
Discussion Starter #26
Oh, but an update to the lights....
I have already cleaned the connectors and used dielectric grease. But dummy me only did the "positive" contacts. When I looked at the part that holds the bulbs, I noticed the "negative/ground" terminals were basically black. Used my dremel and cleaned everything up and added dielectric grease to all points of contact and so far so good. Seems to be fixed.
Just make sure you get some good grade 10.9 stainless nuts and bolts and you'll be fine. I don't think there's any issue with ditching the studs.
Discussion Starter #28
Yep that is what I got. Now, since I am removing the cat... I really wanna buy a race cat and install that instead xD but I heard issues about exhaust sensors and stuff since my 03 has the stupid SAI, plus I really don't have the money sadly
Discussion Starter #29
Also, should the oil be drained before I do this? And if I get the kit, which financially seems more reasonable since the oil delivery line is like 120, do I have to drain the coolant too??? I can't find anything in the WIS for the coolant lines, but for the oil lines, it doesn't say to drain oil nor does it appear that it is assumed..
Discussion Starter #31
Honestly not sure on that. Couldn't hurt to drain both.
Draining the coolant is annoying, cause it never fully drains. I had to drain it to fix my thermostat and it made a huge mess. If I drain the oil i'll just do an early oil change then. Definitely won't hurt, but definitely is annoying haha.
Also, can a simple wrench be used to remove the O2 sensors? Or do I need a special tool?
For the O2, just use an adjustable crescent wrench, I find that's easiest. Unless you have a honkin' 22mm wrench, I think it is.
21 - 33 of 33 Posts
