1. All Linears had 2.0t engine. Badge was probably replaced incorrectly (wreck?) or swapped by original owner.
Chrome edition is funny.
2. All Linears had same brakes. Probably won't see a change going to a bigger rotor alone.
3. Bulbs blowing seems to be a common issue. Make sure you don't tough the bulb as oils from your skin create hotspots on the bulb. Also, make sure the rubber cover is secure so no moisture can get in.
4. Odd. Headlight wires melting is not uncommon. Could be something you can't see.
