Professional Parts Sweden. I will call you out by name. The top rim of the fuel pump is not tall enough to make an appropriate seal. Even if you use their supplied cap screw. Even if you use a Saab OEM cap screw, even if you use the new O ring they supply you with, even if you use the old one, even if you use another new one. Even when you tighten it with a custom made Saab tool you made with a brake press that fits perfectly into the channels like the one photoed in Bentley. It will leak gas out of top of the pump from the edges. I resent them for making me take those brittle barbs off so many times to *wonderful* with it.
I threw a junk yard OEM Saab piss colored yellow fuel pump in (installed and tightened once, one pass) and it sealed perfectly. It sings a little, so I threw another junkyard one in the lower boot.
Beware.
Beware.
