G
Ok, so towards the end of last year my a/c wasnt cooling as well as it should. This year it doesnt cool at all. I have had the gas re done and the system is pressurized with no leaks, but still its not cold.
Has anyone got any ideas :confused:
· Registered
Finn I've been doing loads of searches and all seem to come up with similar ideas that you have already ruled out:
1. Needs Regas (you have had yours done)
2. Compressor failure (would leak probably)
3. Damaged or worn pipework (would leak probably)
4. I assume recalibration shows no faults?
Could it have been disturbed when Abbotts put the large IC in as its right next to the condenser :confused:
· Registered
Similar happened to mine Finn. The fault was the aluminium pipe which runs front to back, drivers side, then accross the front bumper. The mechanic said they are prone to failure because of salt corrosion. Had you had it tested with flourescent/UV addative to the regas which will show any leaks when a UV light is wafted around?Phil.
