My 2004 9-5 blows good cold air on the right and not so cold on the left (driver's side) I would not call it warm air. (temp settings the same on each)
Thinking broken mixing valve shaft, I ran the HVAC diagnostic test (off & auto) result = 0 codes.
Then I inspected the mixing valve parts both the shaft as well as the arm. Checked the stepper motor, watched the operation without the air outlet elbow in place to be able to see it, seems to work correctly.
First time on the forum.....help!
thank you
Dave
thank you
Dave
