Press and hold ECON button. It's not the perfect solution but if I recall correctly, it will change the AC to only operate at higher temp differences between the cabin and the outside.Every time I get in my 2002 9-5 wagon and start the car the a/c automatically comes on. How do you turn this feature off. It always comes on by itself and is annoying.
THANKS for the quick reply. I'll give it a try. It's just annoying when you start the car and it blast air and the compressor comes on when you are trying to start the car. You would think it would default to off after turning the car off. I rather wait for the car to warm up before turning any a/c or heat on. But I think it is amazing the car is so smart that it sense the windshield needs de-iced and turns on the defrost, front and back. Pretty cool if you ask me. These cars where way ahead of their time. Now if I just can get my blend door to work right.....handbook:
Programming I
Manual selections can be programmed into the ACC system so that
these will take effect when the car is started. Note that the ignition
must be switched off for at least ten minutes after programming for
the selections to be saved in the system’s memory.
1 Make sure the ignition is ON.
2 Select the desired settings.
3 Press "off" and "rear window heater", simultaneously
(the display will flash to confirm that the settings have been
recorded).
simply switch it to econ, program it as described above and it will always start in Econ mode without AC.
So true on the 0-6-up 9-5's. It's become an ingrained habit to turn the key to the right, turn off the A/C so the light is green, then start the car.Look in the owner's manual for Programming I and II.
You can set any number of non-auto preferences that always come on automatically. I usually have ECON, and in summer I restrict the fan speed to two bars (to avoid the tornado immediately after startup). That's Programming I.
Programming II lets you set things like minimum temp for A/C, whether rear defrost is on automatically, etc. I know that the automatic rear defrost can be toggled simply by pressing and holding the defrost button for a bit, until there's a beep and SID acknowledges.
Be happy, the '06-up cars can't turn off A/C by default.
It's not just Saabs that do that. Most cars default to A/C on when you set defog/defrost. The reason is simple. A/C is a dehumidifier, so the fastest way to defog/defrost is to remove the humidity/condensation build up. I remember back in the day in my buddies '88 Grand Am SE wondering why when the A/C was off (little snowflake symbol) it would light up as soon as defog/defrost was activated, same in my other buddies Ford Tempo, Pontiac Trans AM, Pontiac Bonneville, Buick Grand National, Chrysler Daytona, Plymouth Laser, JEEP Grand Cherokee and others.So true on the 0-6-up 9-5's. It's become an ingrained habit to turn the key to the right, turn off the A/C so the light is green, then start the car.
Another thing I don't like on the SAAB cars is requirement that the A/C/ compressor needs to be on to defrost the windshield properly. With a few people in the car, it's ridiculous to have the expense of running the A/C on days when the defroster is required.
