i want to leave my a/c and just use the shorter belt, does anyone know what size belt to use or the part number from a local autoparts store? i cant wait for the shipping from pfs.com
Make that a slightly SMALLER belt. Take the 25-060716 number with you and buy the next one or two smaller belts, one should fit perfectlyEric in Lockport said:This belt number will delete the a/c compressor and the problematic Middle pulley.
Good Luck,
Eric
your results may vary
Yes I fixed it. It helps if you put in on the right way;oops:Floyd4321 said:I have the same problem with that belt squealing, What did you do to fix the problem Corn Cob. Thanks
It is easy if you look at a diagram and not do it from memory;oops: My A/C clutch was ingauging and disengauging when the A/C was off and causing a poor idle, so the result was a smooth idle. I would like to chuck all the A/C crap and put in some monster intercooler, plus I bet if you removed all the A/C stuff you would shave off at least 50 pounds.9-3sleeper said:ok guys, how easy is this and what sort of results did you see?
