1 - 2 of 2 Posts
I have a 99 9-5 2.3L turbo LPT wagon with 120K miles. The engine had a slight tap when rebuilt @ about 110K and now has become a knock on rod #4 ( the bearings *were* changed out @ rebuild). This is most likely from oil starvation before the rebuild as there were many leaks. (That's what I get for not measuring the journals). Is there a reliable U.S. source for new or reground and respec'd cranks? My other option would be a short block, but again I'd be looking for a reliable source. Any ideas from those in the know would be appreciated.
O good sued block is cheap and you can check it, there are no reliable parts suppliers for anything right now... You cna have the crank gournd bur will need oversize bearings, agian no soucres ATM, with Saab shut down...
1 - 2 of 2 Posts
